Instrument screeen question on Tiger Cat 2
Sweats
Called. Can't do it. Will explain tonight.
John R
You do have the large canister filter don't you?
Seems Scag should be able to advise you on what to do, have you checked with your dealer?
Sweats
Yes, I ended up calling a local Scag dealer. A couple of the guys there looked around some and found that the 25hp Kohler has a spot on the elbow just below the filter housing for the sensor. The 29hp doesn't have a location for the sensor. We talked about work-arounds but decided against. On the bright side, apparently Kohler makes a sensor I can install; I just won't be able to incorporate it with the Tiger Eye display.
