BarkSlayer
- Jun 17, 2012
- Threads
- 5
- 5
I have a '99 60" Lazer Z with the 25 hp Kohler Command engine with 730 hrs on the clock. I've changed oil and filters on time, every time and last Spring, it began a nasty habit of smoking profusely while under load, blowing thick blue smoke. I suspect I stuck a ring as a result of sitting through the winter (garaged). I've tried Sea Foam in the fuel and it still burns oil until it gets good and hot, 15-20 minutes after startup.
Any ideas on where to start in terms of a cure?
