Every year I have to replace spindle bearings. Is this the norm? I only blow off the mower- no water used on the mower.
The mower will not turn very good- rear tires will spin unless you slow way down. Anything to do to fix this? I weigh 300 lbs.
I bought the Quest about 5 years ago. Second year I installed an hour meter- today the mower has 188 hours.
I replaced hydraulic fluid the second year. OEM recommendation is what- annually? Do I need to do this?
Blades? Who has best price? I usually buy 2 sets for the year- to keep 1 set ready to install. Is there a better brand?
As always-thank you for looking and your suggestions!
