Raptor SD Bagger hack??
Tdciam
I have a 48in Raptor SD that I've just installed a factory bagger on the back. I love how this mower cuts and bags! Only problem I've having is the left side bag fills 2-3 times faster than the right. Anyone having this problem? I've thought about some sort of baffle, but not sure if that will work. Anyone modified or hacked this bagger???
Darryl G
That's pretty much normal with rear baggers. Heavier stuff falls into the right one and lighter stuff goes to the left, in general. The right one will fill more as the left one does and will usually be the heavier of the two. I think it's a non-issue. They both end up full in the end.
Tdciam
Yeah, I think that's the case. This is the first two bag system I've had. From the sound of it, the left bag fills and overflows into the right, until both are full! I guess that makes sense.
