vibration
jimwest
While mowing, Troybilt 50" ZTR suddenly started making a rough noise and vibration. I've completely removed all blades and still have problem. When turned off and trying to move mower belt by hand, all seems fine and tight.
Darryl G
Is this an engine noise and vibration or only when the blades are engaged?
EngineMan
Check all the spindles, idlers and pulleys you may have a bad bearing.
Luffydog
Remove belt and spin each one to find the noise
