meestahmarc
- Apr 17, 2018
- Threads
- 5
- 18
I am trying to get my BS 800 Series engine running on my DR Power Lawn Aerator. I would call myself a newbie (sort of - and being humble).
This is where I am at... last night inspected the engine - gas and oil are both good. Gas was from the seller, but is fresh - not sure what grade it is.
Checked the plug and it looked clean.
I checked the choke (with the air filter off) and that looked good - the little plate inside the carb is moving as it should. I sprayed the carb with carb cleaner.
I detached the fuel line going into the carb, turned it on fuel flow and made sure fuel was flowing.
I put some starter fluid into the carb, several times, and it would run for 5-15 seconds at a time and basically just stall out. I managed to run it enough to get the exhaust very hot.
Questions:
What else should I consider?
There is a throttle near the choke, but I do not see what moves that - not connected to the choke and doesnt move when I change the engine speed lever, is this normal?
THANK YOU VERY MUCH
Questions:
THANK YOU VERY MUCH
