Hi, I have a 8hp TVM195 engine that was on the ride on i purchased.
It died the other week while mowing with fuel coming out the exhaust.
I purchased a carby rebuild kit, installed it all. I set the mixer and idle to 1 1/2 turns and it starts ok. It runs fine except when i enable the blades and start cutting into thick grass then it cuts out and died with fuel coming out the exhaust again.
Im not sure why it keeps doing it.
I looked in the oil and it has fuel in it now too.
Any ideas to try or suggestions.
Thanks
Thanks
