Mower deck Mountfield TDL484 TR spring
EricBradley
Hi all,
I was given a mountfield tdl484tr mower with a shot engine, i stripped the mower a while ago and set about finding a replacement engine, ive now found one and about to rebuild but i cant see where the spring on the underside of the deck fits, one end fits into the mower body but i cant see what it connects to, any ideas would really help.
If you have the single lever height adjustment it will go between the deck and the tie bar connecting the front & rear axels.
You will need to make some sort of spring puller to fit it, they are hard to stretch and usually get stretched a fairly long way.
