398188 is the red seat I am talking about. Flat side or circle groove side towards the needle.
D DarthMoose74 Forum Newbie Joined Mar 15, 2018 Threads 1 Messages 4 Mar 15, 2018 / Red needle seal. Which direction? #11 398188 is the red seat I am talking about. Flat side or circle groove side towards the needle.
I ILENGINE Lawn Pro Joined May 6, 2010 Threads 39 Messages 9,968 Mar 15, 2018 / Red needle seal. Which direction? #12 flat side toward needle.
Boobala Lawn Pro Joined Feb 15, 2015 Threads 200 Messages 7,000 Mar 15, 2018 / Red needle seal. Which direction? #13 HOLEY MOLEY ! ...... Which Which, is Which ..???
K kwgerloff Member Joined Jun 26, 2014 Threads 0 Messages 16 Mar 16, 2018 / Red needle seal. Which direction? #14 Groove side down. The groove side faces the carburetor body. The flat side faces the needle. You can use the flat side of a 3/16th drill bit to install the seat. 34 years of working on small engines . i know a little but not everything.
D DarthMoose74 Forum Newbie Joined Mar 15, 2018 Threads 1 Messages 4 Mar 19, 2018 / Red needle seal. Which direction? #15 So everyone seems to say flat side to needle and circle groove towards carb body. If that is the case, it is good I asked you all, the B&S online help rep said the opposite. LOL
