Hi. Have a b/s engine. It runs very well with ground side to armature disconnected but won't start with wire connected. Armature was bad, put new one with same results, changed ignition switch because connectors were loose got same results. Checked seat switch its good. Can I install a cutoff switch to ground side on armature without damaging any other parts? All wiring look okay hate to change harness everything else works good. Any help of advise will be greatly appreciated. Thanks
