Engage blades,engine shuts down.
biggrass
Hello all new member here
I have a Yard Works 15.5hp. lawn tractor,that when I engage the mower ,the engine shuts off.
I dis connected the reverse safty switch 4years ago so this is not the problem. The blades and pulleys turn freely.
Any thoughts
Thanks.
biggrass
reddragon
there is a blade engagement switch....they often go bad because they're exposed to the wet grass
Edwards saw service
Also it might be a fluke but engaging the blades might cause a significant load on the engine all at once. Try this: engage the blades as soon as it starts to die engage the choke. Quickly closed and quickly opened ( to give the engine more fuel while the pto is engaging) if the engine stays running with the blades on, good! then quickly open the choke back up.
Edwards Saw Service in Glen Mills PA
