Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
  1. #1
    Join Date
    Jul 2011
    Posts
    Location
    Indiana
    Mower
    synthetic or not?
    Hello all, just a quick question on oil changing. My lawn tractor is a new Cub Cadet model LTX 1046 with the Kawasaki 20 hp motor. I plan to put about 5 hours on the break in oil from the factory then it will be ready for its first oil change. I use a full synthetic oil in all of my vehicles but don't know if I should in a small engine. I am partial to Mobile 1 but don't know if they make a 30w or 40w oil. Can some one help....Thanks, Coltscardinalsfan
  2.
  3. #2
    Join Date
    Mar 2011
    Posts
    881
    Location
    Washington
    Mower
    honda 1031, cub cadet 2164, jacobsen park 30, simplicity
    Thumbs up Re: synthetic or not?
    I'd certainly go with a synthetic. Amsoil is my preferred weapon, but any 10-30 will be better than a conventional oil, IMHO.
  4. #3
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    little this...little that
    stay with synthetic!....mobil 1 is great.....i used 10-30 high mileage for years...but once i found ROTELLA T6...i never went back
    '97 MURRAY 15.5hp TECUMSEH..42"...6SP............'04 TROY-BILT BRONCO....18.5 BRIGGS..42"...AUTO...CRUISE...
    '06 MTD YARD MACH...15.5 HP B&S...42"..6 SP ....'99 CRAFTSMAN...19.5 HP....42"...6SP
    '94 AYP KGRO...16HP B&S...42".....5SP ................'77 SEARS 18-6...18HP ONAN ...42"....6SP
    '98 CRAFTSMAN..17HP B&S ..42"...HYDRO............'93 MTD YARD MAN 18HP B&S ...42"....HYDRO
    '02 CRAFTSMAN LT1000.. 17HP B&S...42"..5SP.....'00 MTD 679..17.5 TECUMSEH...42"....7Sp
  5. #4
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    725 Grasshopper JD 430 diesel JD 180 JD Z445
    This spring I bought a new John Deere and the manual said to use either 10-30 or 15-40 so I went with Rotella T-6 5-40
  6. #5
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Rotella T6 5-40 is outstanding Synthetic... KennyV
    If you don't want to switch brands... Mobil1 is also okay...
  7. #6
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    Quote Originally Posted by KennyV View Post
    Yes Mobil would be much better than any dinosaur juice but it needs to be told that Mobil is not a PAO base oil like once was, It is now made from group-3 oil.
    It is still good but when they switched to a cheaper base stock they did not lower the price.
  8. #7
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    Those of you who read this thread but don't really keep abreast of what is going on in the oil industry Castrol was selling oil called Syn-Tech and it was billed as a full synthetic but it was made from a group-3 base.
    Mobil sued Castrol saying they were using false advertising.
    The government decided that the Castrol was refined in such a way as to change the molecule structure enough that they could call it a synthetic.
    After that Mobil switched and started doing the same thing.
    If you can't beat them then joint them.
    Under normal conditions this oil is good enough.
    I use a PAO based oil in my 1200 HP Corvette but it cost me $ 100.00 dollars to change oil so few people need oil this good or would be willing to pay for it.
    I should also point out that the EPA has got into telling the oil companies how they must make their oil.
    In order to make the catalytic converter last longer they told the oil manufactures to lower the ZDDP count and that is when the guys with performance flat tappet cams begin destroying their camshaft.
    All new engine use a roller cam and do not suffer from this but the fact remains that the oil has less protection from dry starts.
  9. #8
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    BEING A TRUCK DRIVER....THESE NEW CATALYTIC BIG RIGS ARE GOING TO OPEN UP A NEW CAN OF WORMS ON THIS FRONT...IM KINDA CRINGING AT ABOUT IT....I KNOW MOST FLEETS DONT USE SYNTHETIC YET BECAUSE OF COST...ILL BE INTERESTED ON HOW THIS PROGRESSES
  10. #9
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    Quote Originally Posted by reddragon View Post
    I retired several years ago so I lost out on what the latest class 8 trucks are using but I think they are using urea tanks and that is a whole different type than what is in a typical car.
  11. #10
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    Quote Originally Posted by Black Bart View Post
    You are right... and that is another of the reasons I stopped using any Mobile1 ... we use to go through a lot of it....
    The reduced ZDDP is and has been a big flat tappet problem... AND anyone with an older engine gasoline & Diesel, should become aware of this...
    Cam operated injector pumps need extreme pressure additives...
    Right now Rotella T6 has the best.
    KennyV
Similar Threads
  1. synthetic or 30w?
    By reddragon in forum Mower & Equipment Operation
    Last Post: 06-12-2016, 04:30 PM
  2. synthetic oil
    By jimbo64 in forum Small Engine & Mower Repair
    Last Post: 08-28-2011, 09:40 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
