Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2014
    Posts
    345
    Location
    Texas
    Mower
    5hp Briggs horizontal with 1" shaft
    Chipper bit the dust. Needing a 5hp briggs, with a straight 1" horizontal shaft. It connects directly to the wood chipper. It's not threaded or tapered.
  2.
  3. #2
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,212
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: 5hp Briggs horizontal with 1" shaft
    https://www.google.com/search?q=b%26...hrome&ie=UTF-8
    you will need all information from data plate on blown engine to match for correct replacement engine
  4. #3
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,540
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    IF Mark's link does not help, here's a few others...
    https://www.briggsandstratton.com/na...nt-engine.html
    http://www.smallenginewarehouse.com/
    https://www.smallenginesuppliers.com/
    Good Luck in your quest !!
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
Similar Threads
  1. Replies: 1
    Last Post: 03-25-2017, 07:17 PM
  2. Vertical shaft with auxiliary horizontal shaft??
    By arch252 in forum Tecumseh Engine Forum
    Last Post: 10-12-2015, 09:06 PM
  3. MTD Huskee with horizontal 6.5hp 120000 series briggS won't start
    By Hsquad12 in forum Briggs & Stratton Forum
    Last Post: 08-16-2015, 01:41 PM
  4. Replies: 20
    Last Post: 03-02-2014, 05:03 PM
  5. Briggs & Stratton Vertical shaft 13.5hp CAMSHAFT Lobes
    By joeschmoe in forum Briggs & Stratton Forum
    Last Post: 05-05-2013, 09:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
