Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2018
    Posts
    Location
    Virginia
    Mower
    Walker
    Walker mower deck cuffs
    Does anyone have any experience with the deck cuff option on the Walker mowers? I canít seem to find any reviews or evaluations of their effectiveness. Are they useful if the grass it fairly tall? Looking at them it appears they might only work if youíre only cutting about an inch or so.
  2.
  3. #2
    Join Date
    Nov 2014
    Posts
    8,257
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: Walker mower deck cuffs
    Walkers are a fine cut mower so not meant for slashing down jungle growth.
    Run them through grass that is really long and the discharge chute continually blocks.
  4. #3
    Join Date
    Jan 2018
    Posts
    Location
    Virginia
    Mower
    Walker
    Thanks bertsmobile1, but this doesnít address my question. For the record Iíve been using Walker mowers exclusively for about 20 years so Iím fully aware or their capabilities. I currently own a T25i with a 48 inch GHS deck. I catch the grass because I donít bother taking it out of the shed unless Iíll be cutting off 3 to 4 inches.
  5. #4
    Join Date
    Nov 2014
    Posts
    8,257
    Location
    Australia
    Mower
    No worries.
    Unless other wise informed I respond to the information presented.
    Good luck.
Similar Threads
  1. Look for Walker deck!
    By yardmasterar in forum Walker Forum
    Last Post: 08-07-2017, 07:05 AM
  2. Torque tension for walker mower flail/swing blades 42" deck
    By Oli699 in forum Small Engine & Mower Repair
    Last Post: 05-05-2014, 03:41 AM
  3. walker deck arms
    By droddy in forum Small Engine & Mower Repair
    Last Post: 10-21-2013, 05:39 PM
  4. Engine Walker mower 42" deck, lever engaged blades not pto switch PROBLEM! HELP!
    By Randallslawncare in forum Walker Forum
    Last Post: 09-13-2012, 09:18 PM
  5. Mower deck Walker deck chute plug?
    By magnoliagrounds in forum Walker Forum
    Last Post: 06-10-2012, 01:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
