Results 1 to 1 of 1
  1. #1
    Join Date
    May 2013
    Posts
    Location
    michigan
    Mower
    yardman
    polan pro powered chute question
    i have a 3 year old polan pro snowblower model may be PR300ES! i'm not in fornt of it now but on the polan site this model all look the same. anyway does anyone happen to know if this series came with the powered chute if so any part number i can get so i can research it or maybe even a line to the parts suppliers?
    or is this model just now able to be converted over to a power chute. or maybe a powered chute unit form another machine as they may all be the same, lots of machine use the same parts anyway. thanks for any help on this.
  2.
Similar Threads
  1. polan pro only runs with brake on!
    By cr999 in forum Poulan Forum
    Last Post: 05-25-2017, 05:45 AM
  2. gravely compact pro chute flap/blocker & wider wheels
    By aussielawny in forum Build-it Yourself
    Last Post: 07-07-2015, 07:44 AM
  3. polan pro
    By jos in forum Small Engine & Mower Repair
    Last Post: 05-01-2014, 11:57 AM
  4. tire question for pro cut 61
    By gapfast in forum Ferris Forum
    Last Post: 05-21-2013, 07:53 PM
  5. Polan tree trimming saw
    By ey8675e in forum Small Engine & Mower Repair
    Last Post: 11-09-2012, 04:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
