I have an Electric Start Kohler flywheel from what I believe was a CH270 Command Pro 7. I think there is a 3 amp charging system such as on CH270-3021 (with 17-025-30-S Flywheel and 17-085-09-S Stator) and a 10 amp charging system such as on CH270-3120 (with 17-025-21-S Flywheel and 17-085-07-S Stator).
The flywheel I have looks like it says TJ208A 170565, but it is hard to read and and those number could easily be wrong.
The other side says 1730024 F, BOD, YP3.
It has a ring gear, three charging magnets on the inside, and one ignition magnet on the outside.
How do I tell if it is a 3 amp, or 10 amp flywheel so I know which stator to order?
Do both the 3 amp and 10 systems output AC and need a rectifier regulator to charge a battery? Which rectifier/regulator would I need? Any 15 amp one should work right?
Thanks in advance,
Bob
Thanks in advance,
Bob
