Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. #31
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,078
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Re: B&S Modell 44R877-0001G1
    ANOTHER kick in the gonads !! was just checkin P/Ns to order some engine parts for perceived up-coming maintenance, and some parts for the 44R engine, just discovered my 2 Barrel NIKKI carb on my 2003 B-S 21 HP no longer displays, it now shows the 1 Barrel carb, similar/same as the carb on motomans, 44 N 877 0001-G1 engine ( haven't really checked the EXACT numbers ) BUT it's still a manifold and carb change-over. about $ 200.00 !!! Glad I can still find repair/replacement parts for the 2 Barrel, .. UNTIL ..??? EVEN the 3rd party parts houses show the 1 Barrel now .......... NO MENTION of superseded P/N or REVISION #s ..NOTHING !!! F &@#$$#@%^$# Briggs & Stratton at their best !
    It's no wonder people ( like me ) get the "ROSY-RED" with them .
    1 NEW CARB.PNG............. my 2003 Engine model showing new 1 Barrel carb. replacement model
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  2.
  3. #32
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,078
    Location
    Mower
    INFO for DEMININ :
    Deminin, here's a pic of the thermostat equipped engine, also I found the start instructions, ... notice there's a COLD 32deg pos. ( which you most likely shouldnt use at all) is this the procedure you've been using, and you have the hard start problem ??
    Attached Images Attached Images
    Model : 465306X8A
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
  4. #33
    Join Date
    Mar 2015
    Posts
    511
    Location
    Illinois
    Mower
    Dixon
    Do any of the 40 & 44 series V twins not have cast iron liners? Never heard of one.
    Walt Conner
  5. #34
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,078
    Location
    Mower
    Quote Originally Posted by Tinkerer200 View Post
    Walt Conner
    This is about the only thing I found about a cast iron sleeve in these models ( so far ) one ad says it, the other does not but I would ASSUME it does since, it has a few other "enhancements" ........
    I have an Intek I/C 21 HP (2003) and it has an iron sleeve ( model 4045A7 )
    Model : 465306X8A
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
Similar Threads
  1. Craftsman Briggs & Stratton Mower Surging & Running Low RPM
    By mitchewr in forum Small Engine & Mower Repair
    Last Post: 07-26-2014, 05:49 AM
  2. Replies: 4
    Last Post: 06-28-2014, 11:13 PM
  3. BRIGGS & STRATTON 14 HP TWIN OPPOSED ENGINE THROTTLE & GOVERNOR ASSEMBLY
    By DANMOWERMAN in forum Briggs & Stratton Forum
    Last Post: 06-06-2014, 11:03 AM
  4. modell 160
    By tschwar in forum John Deere Forum
    Last Post: 04-25-2014, 10:58 PM
  5. CMM1000 B&D Cordless switch lever assembly & putting it back
    By venvis2001 in forum Small Engine & Mower Repair
    Last Post: 07-01-2013, 03:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
