New 5400 series Kohler bucket engine
Learned about the new engine series coming out next year. It uses the same upside down block style as the single courage, but is now a single camshaft(metal gear) engine and the counterbalance system is now a dual shaft system similar to what was used on the old k series engines. The intake, carb, and air filter(which could be the same filter) look similar to the briggs intek single cylinder engines that uses the canister filter.
BlazNT
Thanks for letting us know.
