Tecumseh on wood splitter
Stens has a version they call a mega fire II that is $23.00 that is supposed to replace points and condenser on everything but stihl products. Easy to install. Just clip wire going to condensor and strip the end of the wire and connect it to the wire coming out of the electronic module and the other module wire goes to ground and your done. The past few years when I have had briggs engines come into my shop with no fire that have the points and condensor I have tried changing the components but would still not have fire even with a clean flywheel and would have to go back and take my new parts out and then replace the coil with a new magnetron ignition and just do away with the points.
