Hey guys just joined the forum and recently I have come across a Ariens RM830e lawn tractor with 8 hp Briggs and Stratton. I've only had it about a month now and did have to do some repair on it to get it running. One of the problems I'm having with it now is I have no reverse, all the forward gears seem fine and every so often it will back up in reverse at times. I was wondering if any of you guys have any idea how I can fix this not going into reverse problem, I'm assuming maybe clutch rod adjustment or ?
Tony
Tony
