Engine Honda 2113 - Rectifier SH586B-12 connection
kazik
Please help with connection
Honda 2113 Hydrostatic
Currently all the wires are cut:
I do not know how and what to connect
W- white
G- grey
B - black
I do not know what was left is original wires
Thanks
EngineMan
From what I understand, but check before you do anything......is
Bl (black) = Ground
W (white) = Battery (fuse)
Gr (gray) = Charge Coil
kazik
Maybe you have right becouse white wires are more fat then gray
(2 wires to battery + ?)
kazik
problem solved
