Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2017
    Posts
    Location
    Indiana
    Mower
    John Deere LA140 with Briggs&Stratton Engine-23 HP
    Mower is running rough and sometimes dies out. 2006 Mower with 200 hours on the engine.
    Appears to be a fuel issue.
    Cycled through fuel, changed spark plugs, changed air filter, loosened gas gap and have changed fuel filter twice.
    Do I need to take this tractor in or is there something else that can be done.
    Thanks,
    Hawk1
  2.
  3. #2
    Join Date
    Aug 2017
    Posts
    4
    Location
    Louisiana
    Mower
    Re: John Deere LA140 with Briggs&Stratton Engine-23 HP
    Does the carburator have adjustible jets, they may need adjusting. You may want to check the valve clearance.
  4. #3
    Join Date
    Sep 2017
    Posts
    Location
    Indiana
    Mower
    Quote Originally Posted by Landrycj View Post
    Thank you, will follow up.
  5. #4
    Join Date
    Aug 2017
    Posts
    4
    Location
    Louisiana
    Mower
    POSSIBLE CAUSES:
    Engine Runs Rough Or Stalls
    Engine hand throttled lever not pushed forward.
    Plugged fuel filter.
    Plugged air intake system.
    Fuel cap vent dirty.
    Faulty seat switch.
    Stale or improper fuel / fuel level / water in fuel.
    Dirty or faulty fuel injectors.
    Low coolant temperature. See your John Deere Dealer.
    Fuel pump not functioning properly. See your John Deere Dealer.
  6. #5
    Join Date
    Jul 2017
    Posts
    206
    Location
    United States
    Mower
    Troy-Bilt
    Do you have the twin briggs or the Kohler engine on it. a Briggs is most likely to have the Nikki Carb.
    What you got on the model number for the engine itself ??
  7. #6
    Join Date
    Nov 2014
    Posts
    6,698
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    And rough ?
    That is what I see when I look in the mirror every morning before I take my beauty pill.
    Rough is what the water is like every time I take a boat out.
    Rough is where my ball lands every time I try to ruin a good walk by playing golf.
    But rough is not a description of an engine running that is of the slightest use to people who can neither see nor hear it running.
    Does it miss ? blow dark smoke ? blow light smoke ? cycle up & down, not reach full revs ?
  8. #7
    Join Date
    Jul 2017
    Posts
    206
    Location
    United States
    Mower
    Troy-Bilt
    Ok I see the make and HP now on top of the title LOL
    Your fuel lines could be flapping on the inside of them or one of them. That is a common thing with the ethanol gas now a days. A few bucks to change them might do you some good.
    CJ Landry you from Henderson area or Abbeville ??
  9. #8
    Join Date
    Aug 2017
    Posts
    4
    Location
    Louisiana
    Mower
    Lafayette
Similar Threads
  1. john deere la140
    By B J Y in forum Small Engine & Mower Repair
    Last Post: 07-05-2016, 08:48 PM
  2. LA140 John Deere
    By Johndguy in forum John Deere Forum
    Last Post: 07-13-2014, 07:31 AM
  3. Replies: 1
    Last Post: 06-20-2013, 10:08 PM
  4. Replies: 1
    Last Post: 06-06-2013, 02:10 PM
  5. John Deere LA140 PTO won't engage
    By davemaas101 in forum Small Engine & Mower Repair
    Last Post: 05-20-2013, 09:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
