Results 1 to 8 of 8
Thread: Hydro faults
  1. #1
    Join Date
    Apr 2016
    Posts
    21
    Location
    Texas
    Mower
    721D
    Hydro faults
    I have a RZT 50 Troy bilt and after about 30 minutes of use the right hydro just quits and growls at me. I have to let it rest 30 minutes then take it to the house after it starts working again. I have heard from many people that is a common fault with the MTD made mowers. I have checked for loose components, dirt build up, and broken fans. My wife uses it and keeps it squeaky clean. It has 236 hours on it. I have heard others say that you are lucky if you get much more than 200 hours on a hydro. That makes the machine very expensive since the replacement cost is around $800.00 to $1,000 like buying a new machine every 200 hours. Has anyone found a reasonable repair for these parts?
  2.
  3. #2
    Homer1's Avatar
    Join Date
    Jul 2015
    Posts
    164
    Location
    Kentucky
    Mower
    Scag Freedom Z Pro 52" / John Deere 285 Lawn Tractor, Husqvarna ZTH6127. Ford 8N tractor.
    Re: Hydro faults
    I am guessing you have the EZT transmissions. Here is the link to Hydrogear for the 2200 series, most common. There is a service manual that might help you somehow.
    200 hours sounds low to me personally, hopefully someone with more hours will chime in. Hopefully you don't need a complete replacement drive.
  4. #3
    Join Date
    Apr 2016
    Posts
    21
    Location
    Texas
    Mower
    721D
    Re: Hydro faults
    Quote Originally Posted by Homer1 View Post
    Thank you very much! That seems to be the one I need. I will purge the system first and do a complete tear down this winter if necessary. I will cut a hole in the mower base to be able to purge. I have some hole saws that will work well. I did not want to buy my wife a new mower.
  5. #4
    2,500 Post Club
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    4,067
    Location
    Missouri
    Mower
    RZ5424
    Re: Hydro faults
    Change the drive belt.
    The EZT are not wimpy hydro like some like to say. They will last at least 1000 hours. A person on the forum has a couple of machines with those drives with 1400 hours and not a single problem.
    You can rebuild the drive for a round $200 if it does have a problem.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  6. #5
    Join Date
    Apr 2016
    Posts
    21
    Location
    Texas
    Mower
    721D
    Re: Hydro faults
    I have decided the best course of action is to purge the right side as per directions in the manual. However the method is not clear while the drive is mounted in the mower. I think a hole in the mower frame base is the way to go but before I do that I would like to know if anyone has a different method.
  7. #6
    2,500 Post Club
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    4,067
    Location
    Missouri
    Mower
    RZ5424
    Re: Hydro faults
    Purging a hydro is:
    1. Jack up rear tires.
    2. Move lever to free wheel
    3. Get on the mower and start it. Put throttle to full
    4. Push levers forward for 10 sec then reverse for 10 seconds. Repeat 10 times.
    5. Move lever back to engage the drive wheels
    6. Repeat step number 4.
    7. Turn off the mower and return rear wheels to ground and test drives.
    Chuck
  8. #7
    Join Date
    Apr 2016
    Posts
    21
    Location
    Texas
    Mower
    721D
    Re: Hydro faults
    I have purged as per instructions two times and think I have helped it some. I think it is time to change belts. I have been mowing with it for 30 to45 minutes and it has to have a cool down time to run. My wife uses this mower so it is difficult to get exact symptoms but I think I may have it now. She said it runs fairly well on level ground but when she gets to a small incline it starts to shudder. I think a belt might solve the problem if not it may have a small leak in that hydro. (no evidence of a leak yet for she keeps it very clean. Do you have any other thoughts now. It has nearly 350 hours on it as of today!
  9. #8
    Join Date
    Aug 2017
    Posts
    18
    Location
    Georgia
    Mower
    MTD - Yard-Man
    Re: Hydro faults
    Try the belt first and while the belt is off see if the pully has wabble in it. If that doesnt work, change oil in transaxle. But if all else fails, they are rebuildable even if you have to go to transaxle manufacture for parts. watch google vidios on rebuild
Similar Threads
  1. L115 electrical faults.
    By LeeH in forum John Deere Forum
    Last Post: 04-03-2017, 05:06 PM
  2. Most Common Faults of Lawn Tractors
    By SeniorCitizen in forum Small Engine & Mower Repair
    Last Post: 01-30-2017, 06:24 PM
  3. Repairs New Hydro???????????
    By jmgus in forum Cub Cadet Forum
    Last Post: 05-14-2015, 02:26 PM
  4. Repairs Need a hydro for a 1988 Ariens YT12 Hydro mower
    By benhanjosamab in forum Gravely/Ariens Forum
    Last Post: 01-31-2015, 06:22 PM
  5. Snapper LT1642H, is there a place to put hydro oil in for the hydro? Slipping?
    By jessie_hemi in forum Small Engine & Mower Repair
    Last Post: 09-14-2012, 04:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
