I have the new cable and have a few questions as to how to install it.
1. How do you remove the old lockwasher from the stop bracket by the clutch?
2. What is the best way to install the new lockwasher? Is there a slit in the bracket that the cable goes into? There is so much "gunk" on there, it is hard to tell.
3. Is it best to cut the cable in order to be able to remove the rubber grommet that passes through the deck by the transmission tunnel? I assume that the grommet has to be removed for the new cable to go through it before it is reinstalled.
Any other helpful hints would be appreciated.
Rich
Rich
