Hello everyone.
I have a husqvarna 62522 SH self propelled mower. I am looking to remove the transmission assembly. I removed the wheels the height adjustment bracket and I am able to slide the whole unit back and forth. So I tried sliding the unit all the way to one side and then I was trying to pull down on the other side to drop it down through the bottom of the deck. Seems like there isn't enough clearance to do this. Looking for the solution to this. Thank You in advance.
Robvan
Robvan
