Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2017
    Posts
    Location
    Louisiana
    Mower
    McLane edger
    Engine troubleshooting
    I have an old (1965) McLane edger with a B&S either 2 or 2 1/2 HP motor. It means a lot to me after all these years. My problem is that it starts easily and runs well for about 8 to 10 minutes, then begins to smoke a run roughly, then dies.
    I have replaced the sparkplug.
    Cleaned the carburetor.
    Cleaned the gas tank, good clean gasoline in it.
    The gaskets are good.
    After all of this, again it starts normally. Runs solidly, good throttle response. After 8 to 10 minutes it starts sputtering, throwing out a little blue smoke, then kills. I have no idea what else to try. Does anyone have a suggestion? I would most appreciate it.
    Iveson
  2.
  3. #2
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    3,287
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Re: Engine troubleshooting
    Quote Originally Posted by Iveson View Post
    Iveson
    You did.nt mention the OIL level. and if it's clean or not, did you remove the engine "shroud" and clean the cooling fins ..?? is the plug covered with black carbon ?? what color smoke is it emitting , black or blueish white,what gaskets are you referring to ..??
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  4. #3
    Join Date
    Aug 2017
    Posts
    Location
    Louisiana
    Mower
    McLane edger
    The oil level is fine. Changed not long ago. The smoke when it gets hot is blueish/white. Have not attended to the cooling fins, and do not know how to do that. The gaskets I mentioned were the gasket sealing the carb to the engine housing and the gasket connecting the fuel tank to the mount. The engine shroud is off. Tell me more about these cooling fins please.
  5. #4
    Join Date
    Aug 2017
    Posts
    Location
    Louisiana
    Mower
    McLane edger
    Forgot. The spark plug following the engine dying is indeed wet and a bit blackened.
  6. #5
    Join Date
    Nov 2014
    Posts
    7,382
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Spend $ 20 on a red neon tube in line spark tester and fit it to your mower then go mow.
    If the tube flashes iregularly when the engine starts playing up and does not flash when you are cranking after it has stopped but still hot then the ignition module is toast & needs replacing.
    If you get good strong flashes then it is a different problem.
    Give it a go then get back to us
  7. #6
    Join Date
    Aug 2015
    Posts
    728
    Location
    Kansas
    Mower
    Toro/Cub Cadet/Kubota
    Cooling fins are thin projections, cast integral to the cylinder barrel and cylinder head. Their purpose is to increase surface area of the exterior of the cylinder and head so that heat will radiate from them. Air is drawn in through the screen under the recoil starter by the fins atop the flywheel and is pushed into the sheet metal shroud which is shaped to direct the airflow over the cooling fins. This is how air cooled engines work. Some air cooled engines don't need the fan and shroud, such as motorcycles and airplanes.
    Obviously, anything such as dirt, clippings, grease accumulating on these fins acts as an insulator and reduces their efficiency. Cooling fins need to be clean.
    FWIW, ALL engines are air cooled. "Liquid cooled" engines just have a middleman (the radiator) which transfers the heat to the air.
  8. #7
    Join Date
    Aug 2015
    Posts
    728
    Location
    Kansas
    Mower
    Quote Originally Posted by cpurvis View Post
    I left out probably the most important detrimental effect of dirt, clippings and grease accumulating on the the cooling fins--it blocks airflow over them.
Similar Threads
  1. DIY Small Engine Troubleshooting
    By mechanic mark in forum Briggs & Stratton Forum
    Last Post: 10-30-2016, 05:25 PM
  2. Repairs Electrical Troubleshooting
    By mechanic mark in forum Craftsman Forum
    Last Post: 10-04-2016, 12:03 PM
  3. Troubleshooting Craftsman 42" Riding Mower w/ 16HP Honda Engine
    By cbaur88 in forum Small Engine & Mower Repair
    Last Post: 10-16-2014, 09:48 AM
  4. XD3 Troubleshooting
    By MBaytosh in forum Gravely/Ariens Forum
    Last Post: 09-29-2014, 06:45 PM
  5. Please help! MTD Riding Mower Engine Troubleshooting
    By TopNotch in forum Small Engine & Mower Repair
    Last Post: 10-05-2013, 01:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
