Results 1 to 4 of 4
  1. #1
    Join Date
    Aug 2017
    Posts
    Location
    West Virginia
    Mower
    9HP Tecumseh engine or short block needed
    I have a Craftsman snow thrower Model 536.887993 with a seized engine. Lawn mower shop claims it can't be rebuilt and they can't get a short block for it. Engine part # 143-049-001 according to the shop. Does anyone know of a source for a replacement engine. Seems strange to me that there are not replacement parts somewhere. Any suggestions/advice is appreciated. Thanks!
  2.
  3. #2
    Join Date
    Mar 2012
    Posts
    7,013
    Location
    Wisconsin
    Mower
    Toro
    Re: 9HP Tecumseh engine of short block needed
    If you can get all the numbers off the engine, it would help us alot. Without them we can only guess.
    This is only my opinion, and many will say it ain't worth a darn, as I'm only a retired grease monkey instructor and not a professional mechanic. Use what I post at your own risk as you know teachers only know book knowledge.
  4. #3
    Join Date
    Aug 2017
    Posts
    Location
    West Virginia
    Mower
    The mechanic says there is only the Craftsman number on the machine. Do you know the differences in the 8HP, 9HP and 10HP engines? I see them on ebay and they all look alike. Are they inter-changeable?
  5. #4
    Join Date
    Mar 2012
    Posts
    7,013
    Location
    Wisconsin
    Mower
    Toro
    First of all, the Sears number for you engine is 143.049001. This crosses to a Tecumseh model HMSK90-XXXXXXX. Can't give you the spec number, as my chart does not go that low. Short block number is 756337D, no long available, but you might find one on the web. Most of the basic parts are available, but will need to be purchased individually. If your mechanic is any good he should be able to find them. If you purchase a replacement engine off the web, 1. it must be an HMSK model, 2. make sure you have pictures of all sides to compare, and then consult with you mechanic and see what he says. He will be doing the conversion.
Similar Threads
  1. CV 740 kohler engine want start after we replaced short block
    By DTanner0512 in forum Small Engine & Mower Repair
    Last Post: 05-23-2016, 07:55 AM
  2. Rebuild, short block, long block, or new mower?
    By Sirwired in forum Small Engine & Mower Repair
    Last Post: 08-09-2015, 06:30 PM
  3. B&S engine seized. Short block, whole new engine...or new tractor???
    By caseyinGA in forum Small Engine & Mower Repair
    Last Post: 03-27-2014, 11:45 AM
  4. Tecumseh SBV-5722C Short Block Wanted
    By Mowitalldown in forum Wanted Ads
    Last Post: 06-07-2013, 07:29 PM
  5. Repairs Gas dripping from air filter. CD pack needed. Short block?
    By Gene123 in forum Lawn Boy Forum
    Last Post: 04-03-2012, 02:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
