Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. #31
    Join Date
    Jul 2017
    Posts
    143
    Location
    United States
    Mower
    Troy-Bilt
    Re: Looking for a replacement engine
    Great now you know what you need. But you cant measure like that with a engine on a mower. LOL.
    Now all you gotta do is shop for the cheapest mower you can find with a 6.75 HP engine.
    IL Engine I had a pressure washer come in last week. I changed the mag on it. It has the same exact flywheel as a mower does. So I don't think chops has to worry about that going on his splitter. Same application IMHO.
  2.
  3. #32
    chops's Avatar
    Join Date
    Aug 2017
    Posts
    26
    Location
    North Carolina
    Mower
    briggsanstranton
    [ATTACH=CONFIG]33860 can you fella's see this pic just want to make sure I did it the correct way .
    Attached Images Attached Images
  4. #33
    chops's Avatar
    Join Date
    Aug 2017
    Posts
    26
    Location
    North Carolina
    Mower
    briggsanstranton
    Quote Originally Posted by Boudreaux In Eunice La. View Post
    I was gonna ask about the flywheel glad you brought that up BOUDREAUX
  5. #34
    Join Date
    Jul 2017
    Posts
    143
    Location
    United States
    Mower
    Troy-Bilt
    Yes we can see the pic. Measuring from the mount ring to the end of the shaft.
    The heavy flywheel IL engine is speaking about is mostly for engines that don't have a blade on them. That 21 or 22 inch blade on a mower is helping out the flywheel when you pull the rope to start it.
  6. #35
    chops's Avatar
    Join Date
    Aug 2017
    Posts
    26
    Location
    North Carolina
    Mower
    briggsanstranton
    With that in mind BOUDREAUX IM thinking that was not original motor that came with splitter
  7. #36
    Join Date
    Jul 2017
    Posts
    143
    Location
    United States
    Mower
    Troy-Bilt
    Probably not but we don't know that do we .............
    Someone might have done some welding on there also to move the pump.. I am gonna send you a pm on here so check that..........
Similar Threads
  1. Engine replacement
    By jayd_2 in forum Briggs & Stratton Forum
    Last Post: 06-23-2015, 04:28 PM
  2. Engine replacement
    By ghost1 in forum John Deere Forum
    Last Post: 12-29-2014, 05:21 PM
  3. Snapper rear engine rider engine replacement
    By Mollys dad in forum Small Engine & Mower Repair
    Last Post: 05-11-2013, 03:33 AM
  4. Engine Replacement engine for a rear engine rider
    By ftwflh in forum Snapper Forum
    Last Post: 06-24-2012, 11:54 AM
  5. replacement engine even available?
    By snappin in forum Snapper Forum
    Last Post: 04-22-2012, 07:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
