Let me start by saying I am not an engine guy but I try to get as much done as I can before seeking professional help.
My YT3000 stopped in the middle of mowing recently. I replaced the battery and it started but after running for around 30 seconds it started blowing smoke. The engine had to be replaced a year or so ago because gas had leaked into the engine and the guy that repaired it put a valve in which I close after using. It was open for a while though while I replaced the battery. After doing some research I checked the oil and thought it smelled like gas although I could not be certain. I took the carburetor off and cleaned it out and checked the float and pin, replaced the air and oil filter. Now it won't start. I checked the plug to make sure it is getting a spark and it is.
I don't know if there really is gas leaking into the oil or not. Any suggestions on first why the mower will not start? Secondly on what might have been causing the smoke in case it continues after I get it started.
Thanks,
Scott
Thanks,
Scott
