Results 1 to 7 of 7
  1. #1
    Join Date
    May 2010
    Posts
    557
    Location
    Minnesota
    Mower
    country clipper (jazee)
    fuel ratio for homelite chainsaw
    Hi
    Was wondering if any one know what the fuel ratio for a homelite chainsaw ? Model CS-40 ut number is 10760 ,any help on this will be greatly welcome. Neighbor chainsaw with no manual available. I'm thinking i used this before and don't remember what ratio, before i think i used 32 to 1 or 40 to 1. I'm thinking the 32 to1 would be better but then that might be to oily. well thanks
  2.
  3. #2
    Join Date
    Jul 2011
    Posts
    Location
    Virginia
    Mower
    Ford
    Re: fuel ratio for homelite chainsaw
    With todays modern oils 50:1 is fine.
  4. #3
    Join Date
    May 2010
    Posts
    557
    Location
    Minnesota
    Mower
    Scooterbum
    Do you think i can get by with that lean of mixture? Its a older and mfg in 95 ,i'm thinking synthetic oil will maybe help to and i forgot to get some when i was in town yesterday. I don't know i'm just after options or if some one had a manual for this model, there is a web site for homelite and i have checked there and they no longer have manuals for this unit.And i have even called then and they don't know. wwwhomelite.com
  5. #4
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    little this...little that
    i have found specs for homelite chain saws very close to yours...all use 40-1 ratio
  6. #5
    Join Date
    Jul 2011
    Posts
    Location
    Virginia
    Mower
    Ford
    I have a collection of over 100 chainsaws. Some dating back to the 40's.
    I use a good synthetic oil and mix 50:1 for everything.Never a problem.
  7. #6
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    i agree....with a high grade oil .....50-1 should work....and it will burn cleaner
  8. #7
    Edwards saw service's Avatar
    Join Date
    Jul 2011
    Posts
    74
    Location
    Pennsylvania
    Mower
    Also don't forget the newer 2 cycle oils are designed to be mixed with 89 octane or higher gasoline which is what all newer 2 cycle machines call for and perform best on. ;-)
    Sent from Lawn Mower Forum for iPhone.
Similar Threads
  1. HomeLite string trimmer
    By Oddball in forum Homelite Forum
    Last Post: 07-05-2016, 01:31 AM
  2. Homelite Riding Lawn Mower
    By TomR Ont in forum Homelite Forum
    Last Post: 07-07-2011, 03:07 PM
  3. feul mix ratio needed for Yard Machine 25cc string trimmer
    By suzi_2011 in forum Mower & Equipment Operation
    Last Post: 06-09-2011, 05:49 PM
  4. Oil Ratio
    By danarn17 in forum Small Engine & Mower Repair
    Last Post: 03-28-2011, 07:18 AM
  5. Fertilizer Ratio
    By linda4 in forum Lawn Care & Landscaping
    Last Post: 09-21-2010, 03:50 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
