shwing2345
- Jul 15, 2017
- Threads
- 1
- 5
I have a Honda HRZ216TDA Lawn Mower. Engine stalled one day and would not start ever since. Did not hit any objects. I removed the spark plug, plugged it into the ignition coil, touched the spark plug against the engine body and spinned the flywheel, but did not see any spark. I removed the ground/kill wire and still did not see any spark. I replaced the spark plug and ignition coil and still could not produce any spark. Thinking that it is a defective ignition coil, I asked for a replacement. The OEM replacement part still would not produce any spark. I checked the fly wheel, and there are 2 strips that have magnetic properties. It seems like the flywheel is still good. I am just baffled at what could be wrong. Could i have 2 defective ignition coils? The ignition coil part # is 30500-Z8B-901 and the engine serial number is GJAEA 1986652. If anyone know what else I can check, please let me know.
