Look'n for set of 20X10X8 Rims for 2011 Simplicity 27 Hoss 48" cut Zero momma
poncho144
  • / Look'n for set of 20X10X8 Rims for 2011 Simplicity 27 Hoss 48" cut Zero momma
Any you Mower Heads know where I can get a set of USED 20X10X8 4 Lug Rims? Swapped out Turf Tires for Supper Mudders after convert'n from grass to snow Blade. Now...in the field behind my place knobbies work fine but on the slope just behind the place chew hell outta it. So...I wanna put the Turfs back on diff set o rims sos can qucik change out. Much obliged for any help...lord knows ah need it.
BlazNT
Re: Look'n for set of 20X10X8 Rims for 2011 Simplicity 27 Hoss 48" cut Zero momma
20 is the tire size.
10x8 4 on 4-inch center
Four wheeler rims. Look on craigs list.
poncho144
Thanks for the info, I've searched just 'bout everythang but Craig's.:thumbsup:
the wheels will be a bought in item so there will be a lot of other mowers with similar wheels.
I fit JD wheels to Great Danes because the JD wheels are 1/3the price.
Rears bolt right on but the casters require a little machining to narrow the hub.
Now most people will not know which wheels they have or what it will fit.
If there is a independant mower repair shop any where you take your wheel to them.
They are likely to have a shed full of wheels off old dead mowers that went in the scrap metal bin.
I have better than 200 wheels sitting in my graveyard .
A regular customer who needs one to keep their old mower that I service going then they are $ 50
Some one off the street they are $ 100 so don't expect to get them for free.
poncho144
Thanks for the git back info mate. Unknown Yank in SW Indiana river bottoms.:thumbsup:
  • rambo-brabo-sylvester-stallone-says-rambo-v-is-his-no-country-for-old-men-gif-119336.jpg
