1997 john deere sabre 18 hp vtwin
bigmiketx
i have a broken spring i think it has something to do with blade engagement any ideas how it hooks up one end of it is broke off?
It is either a brake spring or a tension arm return spring
bigmiketx
you have any idea how it hooks up i think it has to do with blade engagement
If you want any more help, I need the model numbers off the ID tag on the mower so I can look it up.
From the size of the spring it will either be on the spindle brake in which case there should be 2 of them or it goes against the engagement spring to aid the dissengagement of the blades.
If you looks closely at the deck there will be scuff marks where the spring has been rubbing the paint.
reynoldston
Its been awhile but as I remember as you sit on the seat on the left side there is a lever that adjust the mower height. The lever go's through a plastic insert and this spring is the levers detent.
