Can anyone tell me if there is supposed to be spring attached to the choke lever. Mine hasn't one and it doesn't have any way to assist back to open position
other than just gravity.
Part 217 in the diagram above from the vendor above.
Check the freight it will most likely be a lot more than the $ 5 part in which case order on from your local B & S dealer
