Turned mower off, now won't start. TB Pony
OldLyme
model number 13wn77ks011
So out mowing, pull the blades handle up and put it in reverse and it starts trying to cut out. I knew something was wrong, put down the blades lever again blades activated, then pulled it up to turn it off again so i could reverse. Same thing happened again. So i shut the mower off... and now it won't start. What went wrong here.... also I'm getting nothing from turning the key. Battery has juice. thanks.
BlazNT
Sounds like the reverse switch is not working. Time to find it and blow all the crud from around it. Then check to see if it is working.
