How are you with a voltage tester? Sounds like one of the safety switches is not working. To test them you unplug the wires going to them then check for continuity. Many different switches so you check for open and closed. Button not presses has one reading and button down reads the other way. Also check to see if they are being pushed all the way. Sometimes they get moved from their correct position.
