I have a 718 Grasshopper Mower ( between 1996 and 1999 ) This mower works great, but the crank shaft bearing near the clutch went, is this motor worth rebuilding? It is the original motor on the tractor. I know they no longer make the hyro drive pumps for this mower so I don't want to dump a ton of money into this motor and have a pump go bad. My question is, does anyone know of a rebuild kit or anything for this engine?
