Firescooby
- Aug 2, 2015
- Threads
- 2
- 2
Bought mower used. After about 45 minutes, hydro oil starts coming out of hydro reservoir filler cap. Within about 5 minutes, I'll lose right side hydraulics. After it sits and cools it's ok for a little while.
Hydro oil DOES look milky and starts coming out after running about 30-45 minutes. Right motor still seems weak.
The screw that adjusts/ frees hydro motors will only turn about 1/4 turn either way on right motor.
I have done the following:
1) replaced hydro res cap and seal
2) changed hydro fluid and replaced with M1 15W50
3) Replaced suction/feed lines going to hydro motors
