I have a bigdog alpha (aka hustler raptor). It had some work done on the smart choke. I feel that the engine is running at a lower rpm than it use too. I bought a digital tach you wrap around the spark plug wire. At wot with no load Rpm is 3150. What is the rpm range this engine should operate and how can I adjust if need be?
