Walk behind SW36A-15KH DC output voltage
JardCrocker
Hi...i am a new user here. As per my experience you should start with the AC voltage.ON Kohlers the AC goes to the outside terminals and the DC comes out of the middle wire. AC and DC ground through body of the rectifier so make sure the earth strap is connected to one of the regulator mounting bolts .
