Results 1 to 7 of 7
  1. #1
    old,oldlady's Avatar
    Join Date
    May 2017
    Posts
    Location
    West Virginia
    Mower
    MTD rider, Hechinger label M# C6 338917 1330673G372
    the seat on my MTD riding mower is totally wrecked from age, how do i replace it?
    i am a brand new member as of may 15, 2017. my 1992 or so MTD rider made for Hechingers has a very worn out seat. i checked with the retail and online sources and found that a new one is $150. does anyone know where i can get a seat that would work? obviously, the mower is a little old but my daughter just ran it through a series of checks and repairs that have her astonished at its quality.
    the only problem i ever had is transferring from forward to reverse so i just mow in a circle. the only time i need to go in reverse is if i hit a fencepost or a tree. when that happens, i just turn it off, go get the digging bar and pry it off the obstacle. my daughter had the same problem going from one to the other and since she is a total mechanical genius i guess it isn't just me. (she built a pickup truck that was featured in a magazine about custom chevy cars)
    i would appreciate any suggestions for the seat, the pictures tell the whole story.
    having lost this entire thing yesterday, i am not going to risk adding the photo here. will try that separately.april-may 2017 027.JPGapril-may 2017 026.JPG
  2.
  3. #2
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    3,253
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Re: the seat on my MTD riding mower is totally wrecked from age, how do i replace it?
    Quote Originally Posted by old,oldlady View Post
    You might find something here to your liking.. I have never had a problem with the Transaxle I purchased here and THEY will help you with questions over the phone ..!! Always getting in new items ,so get a catalog and on their mailing list ...
    click on this link ...http://www.surpluscenter.com/shop.ax...ds=mower+seats
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  4. #3
    Join Date
    May 2017
    Posts
    Location
    West Virginia
    Mower
    Quote Originally Posted by Boobala View Post
    thank you for your prompt reply. i do not know where my photos went, they showed up on my original post.
    i tried the link but after 7 minutes of watching a circle go around, i quit.
  5. #4
    Join Date
    Jun 2014
    Posts
    537
    Location
    Texas
    Mower
    Murray 46/20 rider, Cub Cadet, Honda, Toro and some unknow brand I hacked up
    old,oldlady,
    I must say you handle was hard to type as you Ladies are not old, just aged like a fine wine. OK enough of that. You pictures come through just fine and the link that Boobalo posted worked for me. You might try just typing in the address he posted into your favorite search engine and try that. Also if you have any GOOD farm supply houses in your area you might look there. Northern Tools, Harbor Fright, Tractor Supply all may have a seat that will work for you. All else failing that seat is prime for a roll or two of duct tape.
    Post more pictures once you get the seat fixed, taped up or replaced.
    Tom
  6. #5
    Join Date
    May 2017
    Posts
    Location
    West Virginia
    Mower
    thank you, tom. i used gorilla tape on the seat the first time i tried to fix it. was stuck on the mower for a long time trying to get the gorilla to let go of my jeans. you can see the scars from the tape on the picture of just the seat. score,me one, gorilla zero.
    all of those stores are in the area and i will try the website first.
  7. #6
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,612
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Any universal seat will do. Sometimes you just have to drill some new mounting holes. As I recall the seat switch isn't made into the seat on the MTD's.
  8. #7
    Join Date
    Nov 2014
    Posts
    7,347
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    The Surplues center had spme really cheap.
    I just bought 20 of them.
    You will have to drill a new mounting hole in the plate to fit your mower.
    For now stick some more Gorilla tape on the seat then pull an old T shirt over the seat as a seat cover.
    Skivies are better cause you can use the arms to tie them on.
    Other than that, boating shope usually have a good range of budget seats that are waterproof .
    I have been fitting them for a long time with great success and as most have drain holes they don't give you fishermans bum after being left out in the rain.
    Cheapest is the chair bit from those plastic chairs with steel legs.
Similar Threads
  1. how do i replace a seat switch on an Ariens riding lawn tractor?
    By mikevan in forum Small Engine & Mower Repair
    Last Post: 04-11-2017, 01:39 PM
  2. Replace batteries for G1 Recharge Electric Riding mower.
    By juliej in forum Electric & Battery Powered Equipment
    Last Post: 06-16-2016, 01:05 PM
  3. Repairs Adjust/replace friction wheel WE261 WEEDEATER ONE RIDING MOWER
    By UncleAl in forum Weed Eater Forum
    Last Post: 05-23-2016, 07:25 AM
  4. how to replace the transmission belt on a murray 18/42 riding mower
    By mouse in forum Transmissions & Transaxles
    Last Post: 05-08-2013, 02:34 PM
  5. Craftsman riding mower age?
    By marc in forum Craftsman Forum
    Last Post: 10-26-2010, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
