Blade clutch not working correctly
BBFARMER
I have a silver eagle 2550. My blades quit turning and I assumed the clutch had gone bad but, not quite sure that is the case. With the clutch engage switch in the off (down position) and the parking brake set the clutch engages and the blades are turning. With brake set and I place the clutch engage switch to on (up position) the clutch disengages and the blades stop turning. Electrical problem somewhere. Any ideas as to the solution for this problem would be appreciated.
