Results 1 to 4 of 4
  1. #1
    Join Date
    May 2011
    Posts
    40
    Location
    Rensselaer County, NY
    Mower
    Ferris
    Hydro control on fender
    I was over at Lowes yesterday looking at their mowers. They had some Husqvarnas and the higher priced ones had the Hydro speed and direction control on the right fender rather than foot pedal controlled. The lower priced Huskies and the Deeres all had pedal controls.
    It seems like with this setup one would be steering with one hand a lot and turns, particularly three point, would be very difficult. Is there a benefit to having the direction and speed hand controlled rather than foot controlled, or is this strictly a cost saving measure?
  2.
  3. #2
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    Re: Hydro control on fender
    Over the years I have operated a number of tractors with hand control speed and direction. Once you are used to it, there is not much, if any difficulty with control and steering. I have found with some tractors it is nice to have a spinner knob attached to the steering wheel. The tractors with hydraulic steering do not require 2 hands to turn the wheel.
    I have both hand and foot control for speed and direction on the Ventrac - The foot control is an option. In most situations I much prefer the hand control.
  4. #3
    2,500 Post Club
    JDgreen's Avatar
    Join Date
    May 2010
    Posts
    2,887
    Location
    Michigan
    Mower
    Too many, running or not
    Quote Originally Posted by AndySKane View Post
    My Deere 318 had a hand control (dash mounted) for speed and direction, my Deere 4210 has a foot pedal control. The pedal setup on the bigger tractor is much more convenient when I am using a loader or back blade, but if your machine doesn't use attachments, a pedal setup would be much better if you needed both hands to steer. Both my machines have PS, so I really don't know how much effort is needed to turn a lawn tractor. The design of the footrests and any other controls mounted near them may have a bearing on where the hydro controls are located. I am just guessing here.
    "I didn't plan to do anything today, but by noon I was almost half done...."
  5. #4
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    little this...little that
    i had a JD 155 with the forward and reverse and brake all on the right..once i got used to it its fine but..it was a little too cluttered for me
Similar Threads
  1. My aching knee -- alternatives to foot control pedal?
    By H.T. in forum Mower & Equipment Operation
    Last Post: 07-13-2017, 09:23 AM
  2. Remote Control Mower
    By Mike's grass cutter in forum Build-it Yourself
    Last Post: 08-19-2011, 08:28 PM
  3. Weed Control in my Small Pond
    By Sprinkler Buddy in forum The Front Porch
    Last Post: 05-14-2011, 03:36 PM
  4. Remote-Control Snowblower
    By Wayne195 in forum Snow Removal
    Last Post: 02-10-2011, 08:31 PM
  5. Found You a Remote Control Mower... it's Fast
    By KennyV in forum Build-it Yourself
    Last Post: 09-24-2010, 11:30 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
