Wiring Diagram for a John Deere L130
amesde
I'm trying to find a wiring diagram for a John Deere L130 riding mower. The starter won't make any noise at all, not even the starter solenoid. The battery is charged. I checked the parking brake switch with a ohm meter and it seems to be working. I took the starter off and went to the John Deere dealership and they tested it and said it was good. Without a wiring diagram, I can't trace the wiring to find out where the 12 volts to the starter solenoid is missing.
Solenoid hot side
fuse
Starter switch B terminal
Starter switch S terminal
PTO switch (or PTO safety switch )
brake switch
Starter solenoid trigger wire.
The JD tech manual is the best you will find anywhere in the world.
You can buy them on line as a download cheap or as a paper copy from JD
