briggs model 135202 type 0258-01
Dustinkerr
just replace a on the tank mount carb ,, now it will only start with carb and choke cleaner , once it burns that out , it dies , can anybody point me in the right direction?
Dustinkerr
Thank you , ill take a look, , and basicly ,,its ating as tho the carb isn't pulling fule from the tank
Something to look at. A few years ago I ran into about the same issue. the problem was the fuel pickup that hangs down into the tank was touching the bottom of the tank and prevented fuel from being drawn through the tube.
