Ronno6
- Apr 8, 2016
- Threads
- 24
- 1,933
I have a Huskee mod 14AR808K731 that I use for the lion's share of grass cutting.
54", 26hp B&S V-twin, 2 speed transaxle, variable speed belt drive.
I have replaced both drive belts and adjusted the pedal travel per the manual, about 1 3/8" before engaging if memory serves.
I can't help but believe that it is just not going as fast as it should.
I ran it around measuring speed with my Garmin GPS.
Fastest speed registered was 4.0mph, with 3.4 - 3.8 being more common.
By contrast, my Huskee 13AZ604H063, 46" B&S 22hp, single speed transaxle,variable speed belt drive
easily tops that by a full 1 mph.
Any ideas as to what the typical top speed should be for my big 'un" ??
Is that all there is, or should I try to adjust the speed pedal a bit tighter?
I don't want to get it too snug or I will have a hard time shifting the tranny due to too much belt tension....
I know that capable racer and tinkerer extraordinaire mhavanti will recommend doubling the size of the drive pulley and reducing the diameter of the driven pulley..............but I'd like to know what is normal for the critter before I start kitbashing ...
