I have a Briggs and Stratton (Serial num: 14 0812 58 94318 ). I was trying to replace the spark plug and I think I crossed the threads because I can't even screw in the old sparkplug. Anyone ever have this problem? Thanks in advance.
You might just try to clean up the head plug hole with a 14MM tap if the damage isn't too bad? They make repair kits for people that cross thread spark plugs if that doesn't work for you.
You might think about putting a bit of grease on the tap to catch the cuttings, cut a little, wipe off the grease, add more, cut, repeat as needed. Unless of course you pull the head and do the clean up on the bench. That makes life so much easier.
Tom
