Since this deck doesn't have a power lift, what is the right way to prop up the deck to get to the blades? Jack up the front? If so, what jack do you use? Make some kind of ramp? Remove the deck from the mower and use the deck jack? It doesn't go very high and is worn too much to trust it. Just curious how others service the blades.
It's attached to a 2000 725k.
