cruzenmike
- Feb 10, 2017
- Threads
- 57
- 852
UPDATE:
I finally put the Rotary Blades on the Cub Cadet and gave them a try. Here are my observations:
The rotary blades are noticeably quieter than the factory 2-1 blades. They are durable and held up well to sticks and pine cones. Clipping dispersal is moderate, likely between a low lift and high lift. I could not tell a difference in the size of the clipping compared to the normal blades.
Needless to say, I put the 2-1 s back on for now, primarily due to greater discharge velocity and better clipping dispersal. When fall comes I will try to compare the two types of blades again the leave begin to fall.
Mike
Mike
