Toro 20058 Blade attachment bolts replacement?
ultimatt
I recently aquired a Toro Super Recycler 20058, it runs / cuts great and I could not be happier.
However, during my spring tune-up I discovered that the previous owner crossthreaded one of the blade attachment nuts...ruining the bolt.
Anyone familiar with how to access the bolt for replacement? Do I simply remove the crank bolt and then everything will drop free?
Diagram...talking about part #18...these are the bolts that hang down that secure the blade. Thanks.
View attachment Toro 20058 Diagram.pdf
